Old Jul 18, 2010 | 09:00 PM
  #82 (permalink)
downwardspiral's Avatar
downwardspiral
Default Re: its ugly but getting there... twin-charged SRT-6!!!
Originally Posted by Eric
ok pardon me if this is a dumb question..... you got 14psi coming from the turbo then 14 pounds being pulled from the turbo and pushed in to the engine bye the supercharger.. I understand that if the 14 pounds coming from the turbo was compressed right when it got to the supercharger such as there being a valve that only opened once it got to 14psi then went into the supercharger but with the supercharger always pulling air into it from the turbo wouldn't that lower the air pressure inside the pipe coming from the turbo.. in other words the supercharger would suck some of the pressure into itself before it can get to 14 psi sort of like a boost leak.. or would them both being at the same psi would the supercharger let the turbo even compress the air the turbo is pushing
The turbo is compressing the air by reducing the volume a certain amount of air occupies.. The supercharger will further compress the air by reducing volume the same amount of air occupies. The blower will provide a pressure increase to whatever air is available. If anything, the turbo will be a restriction, letting less air enter the blower. This is kind of a wacky setup, the twincharged setups I've seen were pretty much the opposite of this one in that the supercharger comes first and has a control valve "in series" to ensure that one compressor isn't choking the other.
