Re: Air Temperature Sensor
Thanks for your help. The reason why I ask is I owned a 2001 Camaro Z28 and used a
Air Temperature Module from SLP Performance which plugged into the air temp. sensor. It made the PCM believe the incoming air was cooler than it was. It always worked well in the summer when you can feel a slight loss of power due to the warmer outside temperature. Due you think this would work well with the Crossfire.
