Originally Posted by IBLUBYU
Here's what I know ...... oil is a petroleum product and will break down with use and time...... Mobil 1 (and others) is an oily feeling lubricant, and doesn't break down under normal engine operating temps, but will get dirty like Petroleum based oil. As far as I know, if a synthetic oil is kept sealed in a bottle, or in an engine, and not exposed to moisture, it can last a long, long time.
From Wikipedia:
In the 1970s, typical cars took
10W-40 oil which was used for a duration of 2,000 mi or less[
citation needed]. In the 1980s, to improve fuel economy and engine performance
5W-30 oil was introduced which was then used for a duration of 3,000 miles. A modern typical application would use
5W-20 viscosity oil or
synthetic oils for durations greater than 7,500 miles.
From the early 1980s most oil change shops have been recommending an oil change every 3,000 miles. During the following decades engine technology and oil technology have advanced requiring less frequent oil changes under normal driving conditions. The demands on new motors have also increased placing greater stress on the
motor oil as performance has increased relative to displacement.
Reasons
This recently identified "myth" has continued to propagate due to the complexity existing in today's
car industry. The diverse array of cars and oil types available make it hard for an average person to reliably know what to do and the expert advice of a qualified mechanic is needed depending on driving styles.
In response to this, car manufacturers include a manual with recommendations for how often the oil should be changed
[2][3] often including recommendations based on driving conditions. Some models now come with a monitoring system that alerts the driver when the oil needs changing. Depending on driving conditions, these can extend change intervals to 10,000 or 15,000 miles. In case of diesel engines and manufacturer recommended long-life oil, the indicated change interval can be as long as 19,000 miles (BMW) or 30,000 miles (VW).
