Old Jul 26, 2010 | 08:41 PM
  #91 (permalink)
ChuckNorris's Avatar
ChuckNorris
Default Re: Engine and Transmission from '04 Limited
I still have a block, rotating assembly, oil pans, timing cover, dampener, heads, cams , rocker assemblies, timing set, starter, auto transmission, torque converter, flex plate/flywheel, balance shaft, ecu, bcm, and probably a couple other parts that I can't remember at the moment.
I almost scraped some of the stuff
I'm surprised I still have the heads and cams. I figured someone would be interested in porting and regrinding.
