Old Jul 27, 2010 | 09:35 PM
downwardspiral's Avatar
downwardspiral
Default Re: 73 mach 1 buildup
Originally Posted by +fireamx
My next door neighbor owns a twin to the copper Mach 1 in the photo next to your car.
I remember 71/72/73 Mustangs had a bad rep. because they were just getting too big and heavy, (straying from the "original" Mustang concept). But in reality, they still weighed less than their biggest competion, the Camaro/Firebird.
70 Mach 1's were my favorite, but I still liked the 71 style as well. Its roof sort of reminded me of the Ford GT 40 Mark IV.
Ford GT40 Mark IV - Supercars.net
Have you finalized your plans for the outside?
I'll figure out the paint and bodywork after I finish the engine work, I dont want to mess it up swinging the engine around . The cowl panel is done, I stripped everything to bare metal and POR-15'ed and Transtar seam sealered everything.
My fuel injection setup is coming along, I just need to machine the intake manifold for the injector bungs, get a fuel tank, filters,i ntake elbow, sump and fittings.
So far my setup is:
-Megasquirt 2 v3
-AEM wideband controller/ gauge
-8 24 lb low z injectors (for now, until I can afford the turbo setup)
-Universal 5/8 fuel rail, to be machined to accept 14mm injectors and 3/8 NPT inlets
-a 74mm throttle body from a Cadillac northstar (similar to LS1, but flipped for FWD layout) which I modified to work,
-Weiand x-celerator single plane manifold, which will be machined to accept injector bungs to be welded in.
-Bosch 044 fuel pump (good to 600ish hp)
-XRP pushlock AN line - -8from the tank to the rail, -6 return
-Aeromotive A1000 -6 return regulator w/ boost reference
I will buy a new fuel tank and weld a male -6 fitting to the top of it and weld a 3/8 NPT sump to the bottom of it.
