Ok, Listen up! The best way to clean the interior is to first wipe the dust from all the surfices with a One-Wipe dust cloth. Always keep on in your car. With a simple gental wipe you will be amaized how it holds the dust. Next, take a small 100% cotton towel, soak it in warm water then wring it out till it is just damp. Open up the towel and lightly spray it with Windex several times. Then carefully wipe all the plactic serfaces to remove any dirt and fingerprints. The towel should be only damp and not soaking wet. You can follow up with another dry towel if you wish. Make sure the towels you use are 100% cotton. Make sure that when they have been laundered that you do not use fabric softner, as this will leave a flim on serfaces. Dust the seats with the One-Wipe colth followed by a carefull wipe with a lightly dampened cloth with just water only followed by a dry towel to obsorb any moisture left behind. Interiors should be cleaned gently. Never use harsh cemicals or brillow pads of any kind.
