Re: Centre Console
Two screws from the underside of console hold that silver part on. To get to these, pull the handbrake cover off (Dish soap and a butter knife) and remove the screws under the carpet inside the console. Also two screws holding the console together, just in front of the part you want to remove. If you have the silver part from around the shifter (with the window buttons) out you can see them. Just lift the console straight up a little and pull back. The console just hooks together with four tabs. The wires have enough slack so you can get at the screws you want by turning the console on its side. You will also have to unplug the mirror switch. If you have a cup holder this is the time to get rid of it! The silver part your after has two tabs sticking straight out of its front and two more sticking straight down at about the front of the cup holder plus the two screws mentioned above. Sounds hard but it's not, just go slow and do not force anything.
