Originally Posted by oledoc2u
Sorry, but this condition only changed when you put on new tires...alignment is correct, tire pressure is correct, but what did change? You stated no matter what you did, changing tires, etc didn't help...it isn't the tires. I will bet you if you change brand of tires, it will pull the same. Something happened when they had the rims off the car...does it feel like it tracks straight while braking? If it tracks straight while braking, or if it pulls hard to one side while braking, I would look at the brakes first before changing tires...if one brake is grabbing, even the slightest, it will make the car pull that direction...they had the rims off, then remounted the rims back on...could have moved or caused something to change on the calipers...just a thought...
You beat me again I'm thinking it might be the right caliper also.
