Originally Posted by aazn
anyone got a picture of the factoy sub mounted.. im considering pulling the 6.5" woofers out and replace them with 8" subs.. if there is enough space might be worth it (kicker mids) would be a cheap upgrade if enough space (might need to fibreglass some boxes)
will be worth the effort it it means you can keep you "big" boot
Won't fit in the stock location, i'll try to get you a picture, they're mounted in almost a basstube type design, with the actual speaker cone facing towards the gas tank, you're hearing/feeling the reverb from it. If you're going to go through that trouble i'd say cut into the fabric behind the seats, pull out that entire factory speaker assy. and just go from there. I was considering this for a 3way component set but getting the midbass to sound any decent with a chair in the way just wouldn't happen.
