Originally Posted by jonnyb
OK - I just got back from bringing the car home. It was easy to see the oil seeping out of the oil filter housing in the light. You were right on with the diagnosis.
Is there a trick to getting the leaking o-rings to seal, or should I buy a new filter (assuming o-rings come with new filter). Also, I believe the dealer did an oil change before I bought the car, but I've put about a 1000 miles on the car since I bought it, so why would this start leaking now?
Thanks for the help!
Jon
I've only changed my filter once and I believe there are 5 o-rings that come with the filter. I would check the existing filter and o-rings just to make sure they are in the proper position. Also, the filter needs a little force to get it to seat on the shaft. There is a great thread here somewhere on how to change the filter and properly seat the o-rings. Check it out first.
Good luck.
