Old Aug 1, 2010 | 11:20 PM
onehundred80
Default Re: Final thoughts on Angel Eyes?
I have read through the threads concerning Angel eyes.
-It appears that 125mm is the best fit?
-I have read that the lens can be cut apart from the housing, or heated in the oven. What about a heat gun around the seal to remove the lens?
-I do not want them high power to be seen in bright daylight. CCFL or LED or? Are they available in a warmer color than pure white?
-Any other ideas/tips would be appreciated.
James
A heat gun would only supply a local heat, as you move on the part previously heated would solidify again. You would need all the cement melted to pry it apart and you would probably have to put it back into the oven again anyway as it may set up too much to get it apart in one go.
Your a braver man than I to stick hundreds of dollars in the oven.
