Old Aug 4, 2010 | 05:59 PM
Goldwing's Avatar
Goldwing
Default Re: New Michelin Tires pulling
Agree. After changing out the tires, it sounds like something is binding and causing enough drag to slow down the right wheel, causing it to veer right. Wheel bearing, brake pad, alignment, tire pressure are all suspect although you checked the last two. When you brake hard, you over ride the slight drag.
Last thought...you're sure it's not due to a crown on the road? My XFs are sensitive to tire grooves and the slope they put on the interstate to drain off water -- the wide tires seem to follow these easily.
Now you have to change the subject to "New Continental Tires pulling".
