Re: urgent please help
Is it possible that when you compressed the piston with the c-clamp you pinched the rubber seal?..... Are you seeing any leaking fluids? Check all the break lines and double or triple check that the bleeder valves are closed..... and dont forget to make sure the master cylinder cap is on tight.....
