Originally Posted by vinnie@tvt
Stock are Bosch, but swapping to the NGK 3764 will result in a noticable difference in both idle and throttle response. If you remove the coil packs first, the job only take about 1.5 hrs. If you have the plugs might as well change them.
Never hurts to take a look at your plugs, and if you have them, like Vinnie said, you might as well put them in....you might see other things that need to be worked on as well, like a valve cover leak....lol
