Old Aug 8, 2010 | 09:59 PM
James1549
Default Re: Tires always need air put in them
Take it off the car yourself, spray it down with a soapy solution to determine where the leak is. I suggest you overfill the tire just a bit while checking for leaks. Once you find the leak, point it out to your tire repair shop. Maybe another cracked rim, sidewall checking, etc...
James
