Old Aug 9, 2010 | 09:22 AM
OKC-XFR's Avatar
OKC-XFR
Default Re: Battery Acid + Paint = BAD NEWS!
Originally Posted by Goldwing
I had the same problem with my SRT6 that has an aftermarket battery, but no overflow line. I've gone through the repairs you mentioned twice. Can you tell me where the vacuum line goes because mine is broken but not replaced? I also just noticed that there is only one plug in the two (one on each side) overflow tubes and it looks like it's happening again. I will remove and run an overflow tube down and below the frame - maybe that will help.
I also have inserted the red/green battery pads on all three XFs but I suspect battery overflow rather than corrosion falling off the terminals. The XFs with oem batteries do have the overflow catch boxes.
One end of the vacuum line goes to the rear of the intake manifold, the other end goes into the passenger compartment through the firewall underneath the battery tray - sorry, but I didn't take the time to track down where it ended up. I didn't notice any difference in how my car ran after fixing it, though.
I repaired it with some rubber vaccum hose. I cut off the corroded ends of the existing line, went to AutoZone and picked up a foot of hose that fit tight over the existing line and used it as a splice. I figured the rubber line would hold up better if the battery ever leaked again...
