Re: Difficulty Starting + Solution & Dealer Fix
If it cranks then it's not the usual RCM problem.
Wondering if our fuel filters have a check valve that is supposed to hold pressure in the fuel lines and that check valve isn't working, allowing the fuel pressure to drop. That would explain why it take a crank or two to get started.
First couple of cranks to build up fuel pressure then start after pressure is up.
My thoughts without being there to check.
