Re: Transmission Question
Originally Posted by hcarter
I can't say that they stripped the screw ,the tech said it was turning but not backing out so they couldn't remove the adapter, I ask them to put it back together and I got my car out of there, the leak is very minimal but any leak bugs the crap out of me , so I will either do it myself of take to a independent transmission shop, we have several good ones in the area so thats where i'm at with the leak .... you live you learn .
Mike your right it was the 60's ,wonder if theres a gasket for leaking memory.....
Howard.
It is quite possible that the brass insert that the screw goes into has somehow broken free from the plastic and is turning as the screw is turned. If the screw is just knurled then it may be easy to break the bond, but if it is tapered or somehow keyed in that would be tougher. If the insert is the part that is square at the back as in the picture then I would say it is stripped not loose.
