Old Aug 12, 2010 | 03:15 PM
  #71 (permalink)
Black03AR's Avatar
Black03AR
Default Re: p0410 secondary air injection system malfunction solution?
Hey Solnyc2,
Thats definately the part, there is no real Chrysler part - they will supply you with the Mercedes part - generally Chrysler are more expensive but ask around - try different Mercedes and Chrysler dealerships, I'm sure this part can be had for cheaper. They cost the equvalent of $169 here in the UK.
I would hate for you to spend all that money only for the issue to remain unresolved. Make sure you exhaust all other possiblities before spending your cash, if you know someone else with a Crossfire, try out their RCM in your car. You will most likely not be able to return a new RCM once purchased, as it is an electrical component, as least that's how it is here in the UK.
Best of luck in getting the issue sorted - whilst spending the least amount of money!
Regards
AR
