Re: Intakes: Needswings vs TVT
Originally Posted by Voyager
WHAT???? directions please I don't understand what you mean
Bend some aluminum or sheet metal to fit the insides of your airboxes and adhere them in place.
A friend with a S/C Mustang showed how he did his and it made his S/C whine...
I had some scrap sheet metal - but only enough for the top portion for one box and about 3/4 for the top of the other SL55 filter box. I fixed them in place with some double sided tape (temp) and went for a drive...... and wrrrrheeeeeeeep!! Like an echo chamber...
I bet if you bent the metal so to form three sides it would be even louder... and if you added the TVT metal SL55 intake tubes...wow!!
I bet this would work with the factory filter boxes - but I'm thinking the mufflers on the OEM intake tubes will dampen the sound a bit...
