Old Aug 14, 2010 | 08:43 AM
Toolman's Avatar
Toolman
Default Re: How do I change this Fuse?
The glove box light works off the same fuse as the lighter. If the glove box light works that narrows the problem down to the lighter recepticle itself, or the power wire going to it. Although less likely, you could also have a bad ground (negative) connection with the recepticle as well.
