Re: No Start. RCM IS NOT MY PROBLEM
Since you have seen the corrosion and you say its not bad try terminal cleaner, there is some stuff that we used on SAAB vehicles and its a German or Sweedish product but its called KONTAKT 61 this is really a good product for helping clean corroded terminals and connectors. You might be able to get some from a SAAB dealer ? I would try some contact cleaner, spray down the pins and connector then plug in and out the connector several times to help make better connections. This should help you out in pin pointing where the electrical connection might be bad, and then repair as needed.
