Re: So confused 4ohm headunit with 4ohm amp into the stock 2 ohm amp with 4 ohms speakers
I'm Sorry I Forgot To Mention The Other Option Which Is The Best And Allows You More Flexibility. You Can Use Pac Speaker Level Converters Instead Of The Rca Outputs On The Alpine.the Converters Are Adjustable And You Can Set Them To Really Make You System Sound Great.
Proudgpapa
