Old Aug 15, 2010 | 06:31 PM
32krazy!'s Avatar
32krazy!
Default Re: Best Size Spring Pads!!!
Originally Posted by Germany
Hi. I know ths is an old thread, but its perfect for what I want to ask.
I am just getting the Eibachs installed, without Koni's. I guess the "perfect setup" will still be the same with 5dot in the front 1dot for the rear?!?!
So the part numbers I need are:
Front: A 210 321 05 84 (21mm)
Rear: A 210 325 04 84 (17mm)
I guess I can get these pads at a normal Chrysler or MB Dealership? Does anyone know how much they cost?
Thanks for the help and the info so far.
the rears you have are wrong thats a 4 dot you would want these A 210 325 01 84 (5mm) which are 1 dot look at the 01. that corresponds with the dots on the pads
fwiw i have 4 dots on the front and 2 dots on the rear. oem on both 13dog's srt6 and my 32 were 2 dots front and rear.
mrphotoman you are looking at 4mm per dot drop so fronts and rear only drop 4 mm from oem
you also cant use the front pads on the rear and viceversa
