Re: Best Size Spring Pads!!!
Sometimes I think the 05's and 06's are not the same. I have 10 mm spacers on the front with dot 5 pads with stock size tires, almost no rubbing. With 235's I had too much rubbing. On the rear I can't fit even a 5 mm spacer without hitting the fender lip. I had minor rubbing with a dot 1 and 265/35/19's and a dot 1 pad.
Les
