Old Aug 15, 2010 | 09:37 PM
MikeR's Avatar
MikeR
Default Re: fell on it's nose today...CPS...or what do you think
Doc,
Service manual 8I-6... same place as on the NA.... only for the SRT it is behind the cooling lines going up to the IC...
hglad got the right info.... the Crank sensor and the Cam sensor are used together on startup.... according to the manual, the ECU has to see the correct Crankshaft sensor count within 8 counts on the Camshaft sensor or it wont start and you get the P0335 error... maybe I should change my camshaft sensor too and see if that makes my intermittant cold no start go away...
