Old Aug 17, 2010 | 08:25 AM
BoilerUpXFire
Default Re: New stereo & Speakers
Originally Posted by Joliet John
I think I'll probably want to add a sub in the future. Probably won't need an amp. Not sure.
I think a single 10" or 12" sub in the trunk would be more than adequate.
If you are putting in a sub of any size in an enclosure, you will definitely need an amp.
Could they be fitted? Most likely. Would you want to? Probably not. Mids & highs are very directional. They would get totally lost in the stock setup. I can't imagine there is a reason they can't be mounted behind the stock grill though.
+1, the stock sub location has the driver sitting on its side not facing forward, so you would not want to locate a tweet or a midbass driver here since they would fire into the side of the carpeted area.
Originally Posted by huntsmcgee
since those speakers are 4 ohms does it still put out as much sound as the oems
Yes, they will be louder and sound better than OEMs because of the advances in speaker technology, materials, and efficiency gains over the last 6-7 years, not to mention the OEMs were not fantastic speakers back when they were new. This is if you buy a good set....
