My manual calls that the fuse for
"Electronic Transmission Control (Park / Reversing Lock) and BCM" (This is number 7 in the underhood fuse box on the driver's side.)
So, are you saying the fuse blows as soon as you put it in? Or, if not, just WHEN does it blow?
Sure sounds to me like a major failure in the BCM or transmissoin controls.
Headed to bed .... back on in the morning!
Yes, the fuse blows as soon as I hook up the battery, before I turn on the ignition, or push on the top or spoiler switches. That's why I was afraid of a short, and not just a BCM failure. I have driven the car several hundred miles, and the transmission seems to work OK. Now that I've found the fuse problem, I won't drive it until this is solved. I also did not want to just replace the BCM if there's a short somewhere, as I don't want to blow out a second one.
