Old Aug 18, 2010 | 09:57 PM
InfernoRedXfire
Default Re: Another "Pizza" story - again
If I go somewhere with this, I'll get a large ride cymbal and it'll go on the right.
Tune them? I thought so, but I can't get the snare to sound right. Wasn't gonnna worry about it right now.
There's a **** on the side of the snare drum to adjust the tension on the snares. They need to be fairly tight. Lower the snares, adjust the tension and then raise them back. Be careful not to force it too tight.
If they didn't give you a drum key with the set, you need to buy one. They are inexpensive. The key will allow you to adjust the tension on the drum heads. Lightly tap your drum stick on the drum head close to each rod. The tension at each rod should sound the same.
At the beginner level, this is not all that important on the toms. But most important on the snare if as you say it isn't sounding right to you.
