Old Aug 18, 2010 | 10:39 PM
HyprLtH20's Avatar
HyprLtH20
www.CustomCrossfire.com
Default Re: cloudy headlight covers
Originally Posted by TheDon
Sadly, it is garbage advice as onehundred noted. If you used fine grit sandpaper that doesn't create "gashes" then there would be no need to clear the lenses because they are then foggy, right?
[/URL]
If you have ever wetsanded a heavily damaged headlight you would notice it fog over once its dry. For this reason you must pollish or use some sort of clear protectant.... e.g. clear coat
