Old Aug 19, 2010 | 04:03 PM
onehundred80
Default Re: my liftgate wont lock!!!! wtf!
Originally Posted by ronnieignite
sounds like a huuuge pain.
It would have been a bigger pain if the line had broken with the hatch locked.
If the line is broken in the rubber boot at the top of the hatch on the right hand side, it can be simply repaired by splicing it with a larger piece of tubing that is a tight fit over the yellow existing tube. Hopefully it is accessible enough to get at.
When you pull the boot back you will see some wires, on mine the yellow line was hidden behind these wires.
