Old Aug 19, 2010 | 04:44 PM
onehundred80
Default Re: HELP!! Lights dont blink
Originally Posted by rekcah
i've posted a youtube video of the problem
YouTube - Lights dont blink
Fuse, bulb and battery replaced with no luck. What module controls the blinking of the blinkers when the lock/unlock buttons are pressed?
When using the turn signal it lights up just fine.
From the repair manual.
OPERATION
The Sentry Key Remote Entry Module (SKREEM) has the following functions: receiving and evaluating the Radio Frequency (RF) keyless entry remote signal, actuation of door locks in conjunction with the Central Locking Pump/Security System Module, and enabling the vehicle theft security alarm with confirmation via the turn signals. When the RKE transmitter is operated, an RF signal is transmitted. If the SKREEM recognizes the RF signal as valid, it actuates the Central Locking Pump/Security System Module through the Body Control Module. The vehicle is then locked or unlocked through the power locks system. Connected to the SKREEM is a Sentry Key Antenna Ring which surrounds the ignition lock cylinder. When the ignition is switched on, the Sentry Key Antenna Ring is supplied with power. A data block is transmitted inductively via the Sentry Key Antenna Ring to the SKREEM and then ......
