Old Aug 20, 2010 | 01:08 AM
Joliet John's Avatar
Joliet John
Default Re: cloudy headlight covers
I've seen it done at a crossfire meet by a guy that was using a Headlight Restoration kit from Walmart that consisted of 2200 to 2500 grit wet sand papers and a polishing compound. Turned out like new and no clear coat was used.
Yup. The immediate results will be awesome. Depending on how bad they are, you might start as low as 800 grit. The clear might only make a difference in how long they stay that way, although, as I said in my last post, when 3M was working on their headlight restoration kit, they found an insignificant difference between clear coating or not.
