Old May 17, 2005 | 07:51 PM
CyberGreg's Avatar
CyberGreg
Default Re: door panel removal?
Originally Posted by RickB
The link leaves out one VERY IMPORTANT STEP. Since the door has airbags, disconnect the negative battery terminal and wait 2 minutes for the SRS to discharge. Leave it disconnected while working on the door. This helps prevent accidental airbag deployments.
Thanks Rick you're obviously correct. I will update the PDF once I get home from work. I inserted a warning page that says to do just that.
