Re: Headlamp Freaking Switch!
Well the signal lights work, didn't know about replacing that switch 2 thought(Grrrrr) Checked all fuses and everything is good. I got a 30 day guarantee with the one on EBAY but this switch is better than the one I had in although not fixed so I guess I will keep(only 50 bucks). Hopefully a new one will work. I took the bottom panel off just to have more room, don't think you will be able to slide it out from the side. Take out the air vent on the switch itself, there are 3 screws behind that along with one inside the fuse panel itself. Not hard just time consuming cause of the small space to work....... Good Luck
