Old Aug 24, 2010 | 02:32 PM
  #47 (permalink)
oledoc2u
Default Re: fell on it's nose today...CPS...or what do you think
Originally Posted by goodgenes79
I have been having, I think, similar problems. Mine idles at about 500 or 600rpms after the tune and has lately been rough at times. It has died twice while braking and when it idles rough, it won't pick up until after 800 rpms. If I try to give it gas it hickups and stutters, but again will pick up once rpms are higher. I was thinking it may be fuel filter clogged, cause it is happening more often and getting a bit worse everytime. Following this thread has me thinking of changing out a handful of sensors to cover all angles. Any ideas would be helpful.
I can't promise you it will fix your problem, but this would have been the last sensor I would have thought of. It's not that hard to check, but isn't real easy to see either. Take off the engine cover, look straight down behind the throttle body, sits in the middle of the Y-pipe...the clips slip over the edge to secure it...so to remove, pinch the two sides, pull straight up. My one clip, was all but torn loose. So, it has been trying to blow out for awhile. Rough idle, or no idle and die...were the first symptons...until it blew, then it didn't want to run at all...sounded like it was hitting on a couple of cylinders..
