Thread: Help
Old Aug 25, 2010 | 09:36 PM
oledoc2u
Default Re: Help
Originally Posted by JimmyJames
This is sounds the same as the problem that I had with my SCREEM. 3 second run, then stop, then nothing---disconnect battery and 3 more times. If you research and this is it, you have 30 total tries and the ECM with stop working. There is a program in it that thinks that you are trying to steal the car and will kill the ECM---forever. The dealer HAD to but me one because I showed them what I found and MADE them put this on the work order. Well, the tech went over 30 tries and the ECM was cooked. Good luck. Jimmy
I had forgotten about this, rare, but does happen...and it sure sounds like is this with the 3 start series...better take it to a dealer...Jimmy, did it throw any codes....???
