Old Aug 27, 2010 | 06:43 PM
32krazy!'s Avatar
32krazy!
Default Re: Solve an argument
ok for im back!!! 13dog heres how your speed is determined.
²
Speedometer, the input is transmitted by the
Controller Antilock Brake (CAB) and is determined
using input from the four wheel speed
sensors. The individual wheel speeds are compared
and checked for logic. If significant differences
in individual speed signals are recognized,
the speed is determined from the speed of one
of the front wheels. If the speed signals differ significantly,
it may be due to wheel spin, cornering,
or a defective speed sensor. If the computer
identifies by means of sensor comparisons (comparison
of each side) that the vehicle is cornering,
the speed is determined from the value of
the front wheel speeds. If the comparisons indicate
one or more different wheel speeds, the
vehicle speed is determined from the highest
wheel speed. This also applies if a fault indication
is received instead of a wheel speed signal. In this case, an error bit is also set. If any fault indications are
received for all wheel speeds, the speed displayed is
909.
this is directlu\y out of your servic e manual
its easy to see why your speeds can be off by 5 mph or more
for facts i didnt say a srt-6 couldnt do 160 mph i said YOURS couldnt do it because you have a stock non tuned or delimited car. ecu settings are set at 155 mph , no more no less.
hk phooey you win the teddy bear!!!!
jhm2k your just jealous cause your always in the back!
bmorgan i want a rematch!!
