Old Aug 29, 2010 | 05:06 PM
hykeham's Avatar
hykeham
Default Re: Start Enable not Sent (Error 2071)
The original problem was the ignition switch, the tumblers in the switch were broken so the key would not turn to the first position. After replacing the part, the switch now cranks the engine but the engine will not start due to error code 2071, which could be something the mechanics have done to create a new problem.
Next week the mechanics are going to be in contact with Mercedes to hopefully walk them through the problem. Appreciate the help so far, thanks, especially the manual which should be useful. I’ll have a good look at the manual if Chrysler doesn’t get anywhere. If anyone has anymore ideas that would be much appreciated as anything at this point would be helpful.
Specifically any ideas of the error code 2071.
Thanks,
Kevin
