Re: Still wind noises
Thank you for your advice. As I'm from Europe I have not much access to AuroZone unless I sign up. Therefore I'll check our shops. Now my questions: what insulation did you buy? does it concern stock rubber insulation for the door? did you put it all the way behind the stock insulation or just partly? Is the stock insulation glued?
Thanks
