Originally Posted by Joliet John
I'm not real hip on the factory spoiler that can't decide if it wants to be a spoiler or not. I wouldn't mind adding one of these spoilers and disabling the OEM spoiler somehow.
You can pull the fuse for the motor but the spoiler switch will blink once you hit 62mph and it wont stop until you cut off the car.
Or you could pull the spoiler assembly off and remove the motor and simply make brackets to hold the spoiler down but you'd need to figure out how to get around the ecu side of the spoiler, unless you simply pulled the switch off out of the dash and pulled the led out.
