Crankshaft Position Sensor
Sep 3, 2010 | 08:45 PM
113
permalink
Crossfire725
May 2009
606
North Jersey
Re: Crankshaft Position Sensor
Quote:
xfire2005
This should do it for you.
Service and Repair
REMOVAL
Disconnect the negative battery cable.
Remove the air cleaner housing.
Disconnect the crankshaft position sensor harness connector.
Remove the retaining bolt and the crankshaft position sensor (1).
INSTALLATION
Install the crankshaft position sensor (1) to the engine. Tighten to
8 N.m (71 in. lbs.)
Connect the crankshaft position sensor harness connector.
Install the air cleaner housing.
Connect the negative battery cable.
can you reup pics. or can comeone please explain more how and where. thank you very much
Crossfire725
View Public Profile
Find all posts by Crossfire725
