Old Sep 4, 2010 | 06:42 PM
CaptDave's Avatar
CaptDave
Default Driver Low Beam went out
Driver side low beam went out last night, so read up in the forum, did not want to spend a lot of money or go to a lot of trouble, so I shopped Advanced Auto Parts and found some upgraded bulbs which normally run $40 pair, on Labor day sale for $34 plus tax... and did the replacement for both driver and passenger sides.
Wow, you need small hands and long fingers for this job. The wire bracket will swing up if you can get the wiring harness unplugged. That seems to be the easiest way to go about it, took me 45 min to figure out the first one and 5 mins to replace the passenger side. Tonight I'll see how well they are aimed, although not sure there is any adjustment unless the long plastic bolt (3 inches or so) out the back of the headlamp assmembly is the adjustment for up and down. Anyway... Thank you Crossfire Forum!!!!
