Old Sep 5, 2010 | 12:58 PM
onehundred80
Default Re: Air Conditioner Compressor
Originally Posted by kingkub57
Legaly it should be recovered and then you can re-use it, but you have two lines for the a/c low pressure and high pressure, you connect R-134 gauges to them and just open the valve a bit and let it go, but then you have to get more freon and re-charge the system after your all done make sure you replace your seals/o-rings and such, and make sure your compressor has enough oil in it as well, see the sticky for shop manual and it should give you all the procedures for this repair.
Get it removed at an auto AC shop, they will plug the lines so nothing contaminates the system, anything else is illegal and not good for the environment. This stuff is not so bad as the old stuff but ...
When you go back to the shop they can refill it like it should be done. With a new compressor you need it filled just right.
