Re: Massive Oil Leak!
well, here's the rub, and 180 is right on. Amercan vs European. We are all used to flat rubber seals when we did our oil changes, and these are O rings. Follow 180's advise...we can tightened down a little harder on a flat rubber gasket and get away with it, even though we all know to hand tighten a regular oil filter found on US produced cars. I use a filter wrench to remove mine, but hand tighten when re-installing, the same way I did regular US oil changes...never use a wrench when re-installing. For those first timer, just pull out the old filter assembly set it aside on a towel, or clean rag, lay out your o rings, pull the filter off, note o ring positions, remove the old install the new.
