Old Sep 6, 2010 | 04:00 PM
Hambletonian's Avatar
Hambletonian
Default Re: Sluggish Acceleration
thanks ill check it out and research resetting the throttle control mem...
The throttle response memory establishes a 'memory' of your driving habits and applies that 'memory' to the accelerator-by-wire module of the ECU. If one drives like an old lady, the memory (over time) takes set in the ECU and adjusts the response lag accordingly. On the other hand, if you drive like a nut, the accelerator reacts more quickly and is memorized as your driving style within the pedal/wire system.
To reset the throttle response memory:
  • Turn key to ON position.
  • Press accelerator pedal all the way down.
  • Wait five seconds.
  • Turn key to OFF.
  • Let pedal back up.
  • Wait five minutes before driving away.
The response memory is thus reset to factory 'zero' so to speak, giving the accelerator-by-wire system the fastest OEM response time. The difference should be noticeable. But if this still doesn't blow your skirt up, consider investing in a $300 Sprint Booster module ... an easy installation that, some say, is well worth the money.
