Originally Posted by G-Freak
im not a fan of putting a massive intercooler because then the other cooling systems suffer ie oil, trans, engine coolant, ac, etc.. I had a saab 9-3 turbocharged and the stock system had zero cooling issues but then again it was a 250hp car, but my buddy has a 300zx TT with all the bolt ons you can get running at 415 at the wheels and his overly massive air 2 air IC has caused major cooling isues for all for of his other cooling systems...
what do you think of doing:
2. separate the cooling system from the i/c sytem. free and turns a high pressure i/c loop into a low pressure loop cost FREE!
3. run an 80/20 mix with water wetter type product instead of 70/30 mix in the i/c coolant system. water cools faster than antifreeze
5. 180 tstat cost $100- not sure what this does please explain.?
6. -10 * fan mod. cost $50 this mod turns the fan on 10* sooner than oem to work inconjunction with the 180 tstat
7. complete fluid flush and rinse. then refill with 50/50 mix of m/b coolant and distilled water cost 25$
8. remove the rubber strip at the rear of the hood to allow heat to escape. - would this be a problem during rainy days on the underhood electronics and so on getting wet..as this is my daily driver? cost free! some remove the bottom pan as well but i kept mine as i noticed a lift in the front of my car in excess of 150mph
im just looking to have the power there when i need/want it i hate the fact that when i "hit the gas" the performance result is a coin toss.... im going to have the IC pump checked out..
the large h/e is the biggest part of the puzzle. with it installed it raised my engine temps by 10*C. thats were the 180* thermostat (tstat) comes into play along with the fan mod. temps now back at 80*C were they belong
if you separate the systems you want more water than coolant. granted if you live in the northern zones you need more coolant as the seasons change. water wetter is ok but i just stick with whats easiest.
i havent had any problems with the rubber strip removed and rain been in some big storms and no issues
