Old Sep 7, 2010 | 07:06 AM
hcarter's Avatar
hcarter
Default Re: Drilled & Slotted brake rotors
Originally Posted by Bigkid
Voyager, for what it is worth I can feel the difference. Can't say if it is the brake lines or the dot 4 or a combination of the two as they were installed at the same time. I also own a SRT roadster witth stock brakes and if you drove one and then the other you would notice a difference as well. In aggressive driving, like at the limits of your skills, as the brakes heat up I am sure anyone will be able to feel the difference.If you follow me thru the Dragon not even a quarter of the way thru the 318 turns I bet you will see the difference as I will out brake your stock system in every turn.....or maybe not. That is what makes it so much fun. Btw it was suggested that I make the change after a stock MB line went bad.
I agree here 100% the last time we ran the dragon my brakes where hot and where fading really bad ,there is a real noticable difference with the SS lines i get alot more feedback from the pedal , firmer pedal also, this next trip to the dragon should be a different experence as now everything is in place ,look out Jim here I come ...crazy button off.
