Old Sep 8, 2010 | 08:34 AM
onehundred80
Default Re: Brake Booster Vacuum Line Removal?
Originally Posted by KrzyFast
Nobody knows how to take the vac line off the brake booster?!?
I don't feel so bad.....or is it so simple everyone refuses to answer the ridiculously simple question?
I more than likely need a new one - again so if someone knows how to find one online that would be greatly appreciated....I have searched and searched but could not find it. Arg!
KrzyFast
If you pull the check valve out of the grommet in the booster unit it should be easier to pull the pipe from the check valve. The check valve just pulls out of the grommet as it is a vacuum and needs no further clamping.
If the pipe is hard to remove, as I suspect it might be, you may have to warm the pipe with a hair dryer a little.
