Old Sep 9, 2010 | 01:41 AM
ProjectMayhem's Avatar
ProjectMayhem
Default Re: Traction Control/ABS Help
Originally Posted by scsponger31
No warranty for me . I will follow your instructions, as I have wanted to disable the TC anyways. I would, however, like to fix the stupid car still on top of it so I can sell it one day.
Also, what happens when you do not turn of the TC?
Now keep in mind the TC(traction control) BAS(brake assisted steering) and ESP(Electronic skid protection?) are all seperate in how they use the brakes to controll the vehical. Steering in the case of BAS/ESP and reducing rear tire spin in the case of TC.
Unlpugging the yaw sensor essentialy disables the BAS/ESP because input from that is used to correct your steering inputs by applying varrying degrees of braking power to all 4 corners. DOes that make sense?
